Populate list from arcgis server service in JQUERY instead of DOJO?
I would like to populate a list on a select combobox using jquery with data from an arcserver service.I'm wondering if this is possible and if so how i would implement it. I'm using the esri javascript api v3.13 and arcserver. I did it before using DOJO but now i need Jquery instead of Dojo to implement my old code with Bootsrap web mobile aplication.
What i need is to click on the select option and the code should access to an unique field in my service layer and then it should show which value options i could choose(For example a field called Visietd which unic values are yes or no)
For example how should i write dijit.byid("fiedname") in jquery instead of Dojo??For example how should i write dojo.addOnLoad(init) in jquery instead of Dojo?? Any idea? Thank you very much.CODE WITH DOJO INTENDED TO BE CHANGED TO JQUERY: The code below makes a query in my service filtering the field "Visitado" :After this that data is stored with the unique field options values and it is populated the list (in a select in the html) with that options.
Do I need to change everything, or perhaps it is ok only changingdijit.byid (maybe with $("#Visitado")) and dojo.addOnLoad(init); ??
function init() { var queryTask7 = new esri.tasks.QueryTask("http://localhost:6080/arcgis/rest/services/telefonica/brazil/MapServer/0"); //Define query parameters var query7 = new esri.tasks.Query(); query7.outFields = ["Visitado"]; query7.returnGeometry = false; query7.where = "Visitado ''"; queryTask7.execute(query7,populateList); } function populateList(results) { //Populate the dropdown list box with unique values var zone; var values = []; var testVals={}; //Add option to display all zoning types to the dropdown list //values.push({name:"ALL"}) var features = results.features; dojo.forEach (features, function(feature) { zone = feature.attributes.Visitado; if (!testVals[zone]) { testVals[zone] = true; values.push({name:zone}); } }); var dataItems = { identifier: 'name', label: 'name', items: values }; var store = new dojo.data.ItemFileReadStore({data:dataItems}); dijit.byId("Visitado").set("store", store); } dojo.addOnLoad(init); // HTML CODE NEEDED FOR JQUERY AND BOOTSRAP Visitados: //NEW HTML CODE NEEDED FOR JQUERY AND BOOTSRAP
