Populate Integer Field based on Text Field
Using ArcGIS 10.2.2
In the picture below, I want to populate the Spd_Class field (short integer). The value of the Spd_Class attribute will be based on the TYPE field -
residential = 30secondary = 35primary = 50
is there a quick way to use the text field in TYPE to populate Spd_Class? I've been unable to think of a way to do this.
Thanks
