Point pattern fill with only full points in QGIS
I would like to fill a fairly complex polygon with a point pattern fill, but the border of the polygon "cuts" the circles and the result does not look as clean as I would like.
I know it is this is how it should be, but is there a way to use only full circles/points/dots? For example, showing a black dot only if its centre is contained within the polygon (and even if part of it is outside the polygon).
Cheers
