I'm trying to export a table from PostGIS using pgsql2shp. The basic query to export the entire table works fine using the following format:
"C:\Program Files\PostgreSQL\9.1\bin\pgsql2shp.exe" -f "D:\path\shapefile.shp" -hlocalhost -p 5432 -u postgres -P xxxx mapdata planning.dm_planning-appsHowever when I add a query (which works fine in PGAdmin III) the command fails, due to the hyphen in the table name.
Working query in PGAdmin:
SELECT * FROM planning."dm_planning-apps" WHERE "dm_planning-apps"."Modified_Reference"ILIKE '%np%'Included in command:
"C:\Program Files\PostgreSQL\9.1\bin\pgsql2shp.exe" -f "D:\path\shapefile.shp" -hlocalhost -p 5432 -u postgres -P xxxx mapdata "SELECT * FROM planning."dm_planning-apps"WHERE "dm_planning-apps"."Modified_Reference" ILIKE '%np%'"Produces a "syntax error at or near "-" and highlights the hyphen in "...FROM planning.dm_planning-apps WHERE...". The double quotes obviously aren't doing the same job they were within PDAdmin where the query worked fine.
Can anyone suggest a way to make this query work without renaming tables?
