I'm trying to create a several hundred polygons in ArcGIS 10, each of which may have up to several hundred vertices. For consistency sake I would like each line segment in these polygons to be of a set length, say 10m.
I know you can right click and set the next segment length (or use the keyboard shortcut "Crtl L") as you are drawing, but this is going to insanely repetitive if I have to do this thousands of times. Is there a way to permanently set the segment length as you are drawing a polygon or polyline?
