Overlap Macro for Lidar
Using Terrascan, is it possible to run a macro to class flightline overlap points accurately. After a macro has already been run on the lidar data to create the ground class and has been manually edited into ground, unclassed, as well as high and low points. Without needing to manually edit the ground class again. This is my first project on the processing end of lidar (macros/terrascan) and forgot to run a macro for overlap prior to running the groundclass macro. I also do have a trajectory file for the data set.
