My point is to use pgrouting with planet data. osm2pgrouting fails at importing whole planet, so I tried osm2po. Looked fine, it generated sql file in around 2,5h. After importing it to the db though I found there are many ways excluded from the db. Looking closer at osm2po logs:
INFO 46,421,095 of 235,414,299 ways extracted - 25,018M So I commented out every wtr.finalMask entry in osm2po.config file. It helped a bit:
INFO 74,660,756 of 235,414,299 ways extracted - 15,761M but still there are many ways missing. So I uncommented this one line:
disablePreFilter = true But then right before way extracting I got this:
INFO 2,362,909,765 of 2,362,909,765 nodes extracted - 29,114M FATAL Exception at Thu Jul 02 07:34:50 CEST 2015- 8,932M Message: java.lang.RuntimeException: java.lang.ArrayIndexOutOfBoundsException: Array index out of range: -2147483648 Class: java.lang.RuntimeException Stacktrace: de.cm.osm2po.converter.OsmXmlParser.parse(OsmXmlParser.java:83) de.cm.osm2po.Main.runTiler(Main.java:214) de.cm.osm2po.Main.main(Main.java:159) After reading all the answers here I understand osm2po doesn't extract ways with tags it doesn't know. Do I understand correctly that disabling prefilter should extract all the ways? If so, is there any way to configure osm2po to build sql file with all the ways from osm?
