I am currently attempting to use OSM Bright to quickly style some OSM data, so I can export tiles without spending hours writing Carto in TileMill.
This is my first time using osm2pgsql to import OSM (.pbf) data into PostgreSQL. It seems that I am running from one issue into the next (missing style file, no hstore, etc. ) and I have just hit a point where I am not sure how to progress anymore.
The following message keeps popping up:
Error: Connection to database failed: FATAL: database "gis" does not exist I have nowhere entered that I want to access a database called gis .
Executing the help command and looking at the docs I realize that:
-d|--database The name of the PostgreSQL database to connect to (default: gis). Which tells me that it is most likely looking for the default database, which I do not understand, as I have indicated to use my already-created database (ethiopia):
Here is the command I have entered, and I would greatly appreciate it if anyone could tell me what I might have missed:
F:\randomGISstuff\ethiopia>osm2pgsql -c -G -U postgres -S -hstore F:\randomGISstuff\ethiopia\default.style -U postgres -d ethiopia ethiopia-latest.osm.pbf If it is easier for you to look at a cmd screenshot, here it is:
PS: the command that is featured on the OSM Bright page is definitely not sufficient in my case.
EDIT SOLUTION:
Because the solution is all hidden in comments, I will mention here what solved my issue:
1) Create a database and add the hstore to it:
CREATE EXTENSION hstore 2) make sure to set the password, not in the osm2pgsql statement, but before, like:
SET pgpassword=postgres 3) start osm2pgsql
4) Execute the following command:
osm2pgsql -c -G -U postgres --hstore -S F:\randomGISstuff\ethiopia\default.style -d ethiopia F:\randomGISstuff\ethiopia\et hiopia-latest.osm.pbf
EDIT SOLUTION:
