OSM layer does not print in GeoServer printing module
I am new with the GeoServer printing module, in GeoServer version 2.6.0, freshly installed a few days ago.
I can now print WMS layers and I think I configured the OSM data correctly. But it still does not work for printing OSM, so I must have mistakes somewhere.
I am using OpenLayers and the default url for OSM seems to be "tile.openstreetmap.org"
I have set up the OSM url in the hosts section in the config.yaml file:
- !dnsMatch host: tile.openstreetmap.org My printing url is constructed as follows:
var url = 'http://xxx.xxx.x.xxx:8080/geoserver/pdf/print.pdf?spec=';var options = { units: 'm', srs: 'EPSG:900913', layout: 'A4 portrait', dpi: '300', mapTitle: 'This is the map title', comment: 'This is the map comment', layers: [ { baseURL: 'http://tile.openstreetmap.org', singleTile: false, type: 'OSM', maxExtent: [-20037508.3392,-20037508.3392,20037508.3392,20037508.3392], tileSize: [256, 256], extension: 'png', resolutions: [156543.0339, 78271.51695, 39135.758475, 19567.8792375, 9783.93961875, 4891.969809375, 2445.9849046875, 1222.99245234375, 611.496226171875, 305.7481130859375, 152.87405654296876, 76.43702827148438, 38.21851413574219, 19.109257067871095, 9.554628533935547, 4.777314266967774, 2.388657133483887, 1.1943285667419434, 0.5971642833709717] }, { baseURL: 'http://xxx.xxx.x.xxx:8080/geoserver/abc/wms', opacity: 1, singleTile: true, type: 'WMS', layers: [layers], format: 'image/jpeg' } ], pages: [ { center: [center.lon, center.lat], scale: map.getScale() } ] }; var printUrl = url + JSON.stringify(options); As you can see below, the WMS layers are correctly printed, but the OSM layer does not appear, even though there was no error message during the printing.
http://we.tl/nI6y7lNNhV
