I am trying to use OSM data using mapserver (ms4w) on windows based on this. Set up all tools and downloaded data for this purpose.http://download.geofabrik.de/north-america/us/georgia-latest.osm.bz2
Extracted osm2pgsql(cygwin package) to C:\cygwin\osm2pgsql
Imported OSM data into Postgresql OSM database using(osm2pgsql) the following commands
But, when I tried the same on my Windows Server 2012 I get the following Errors:
Confirmed postgresql 9.4.1 is running on localhost:5432C:\Users\Administrator>psql -U postgres -p 5432 -h localhostpsql (9.4.1)WARNING: Console code page (437) differs from Windows code page (1252) 8-bit characters might not work correctly. See psql reference page "Notes for Windows users" for details.Type "help" for help.postgresql.conf contains the following:listen_addresses = '*'port = 5432 And
The pghba.conf has got:# TYPE DATABASE USER ADDRESS METHOD# IPv4 local connections:host all all 127.0.0.1/32 md5# IPv6 local connections:host all all ::1/128 md5#host replication postgres 127.0.0.1/32 md5#host replication postgres ::1/128 md5host all all 0.0.0.0/0 md5#host all all ::1/0 trustHow can I successfully import the osm data as did in local PC?
Thank you.
C:\cygwin\osm2pgsql>SET PROJ_LIB=D:\ms4w\proj\nad
C:\cygwin\osm2pgsql>osm2pgsql -U postgres -l -d osm -p osm -W -E 4326 -H localhost -S "C:\cygwin\osm2pgsql\default.style" georgia-latest.osm.bz2
I am not sure why is it -p osm, anyway it got imported.Then created mapfile using google.style and run a map successfully on my local PC (windows 7). C:\cygwin\osm2pgsql>osm2pgsql -U postgres -l -d osm -p osm -W -E 4326 -H localhost -S "C:\cygwin\osm2pgsql\default.style" georgia-latest.osm.bz2
C:\cygwin\osm2pgsql>osm2pgsql -U postgres -l -d osm -P 5432 -W -E 4326 -H localhost -S "C:\cygwin\osm2pgsql\default.style" georgia-latest.osm.bz2
osm2pgsql SVN version 0.85.0 (64bit id space)
Password
input correct password)
Error: Connection to database failed: server closed the connection unexpectedly This probably means the server terminated abnormally before or while processing the request.When I try removing "-H localhost" it gives another error like this:osm2pgsql SVN version 0.85.0 (64bit id space)
Password
C:\cygwin\osm2pgsql>osm2pgsql -U postgres -l -d osm -p osm -W -E 4326 -S "C:\cygwin\osm2pgsql\default.style" india-latest.osm.bz2
Password
Error: Connection to database failed: could not connect to server: No such file or directory Is the server running locally and accepting connections on Unix domain socket "/tmp/.s.PGSQL.5432"?I have checked the following: osm2pgsql SVN version 0.85.0 (64bit id space)
Password
Thank you.
