OSGeo4W and GDAL - gdal2tiles.py error
Wondering why gdal2tiles is throwing errors, I've added the gdaldata and gdalplugins environmental variables and my python is at Python27/ArcGIS10.3/, and am wondering if that is messing with the OSGeo4W python located in the C:\OSGeo4W\bin folder, or do I need to direct my environment variables every time I want to use OSGeo4W vs. ArcGIS python versions? Or is it working and the error I'm seeing below has to do with something else totally seperate?
This is really confusing to me, thanks! --and the stackexchange tag should be "gdal2tiles.py" there is only "gdal2tile" available...I don't have enough cred to add one
OSGEO4W home is C:\OSGeo4W\
-={ OSGeo4W Shell Commands }=- bmp2tiff listgeo raw2tiff cs2cs nad2bin rgb2ycbcr curl ncdump rpcgen dllupdate ncgen rpcinfo fax2ps nearblack testepsg fax2tiff nircmd textreplace gdaladdo nircmdc thumbnail gdalbuildvrt ogdi_import tiff2bw gdaldem ogdi_info tiff2pdf gdalenhance ogr2ogr tiff2ps gdalinfo ogrinfo tiff2rgba gdallocationinfo ogrlineref tiffcmp gdalmanage ogrtindex tiffcp gdalserver opj_compress tiffcrop gdalsrsinfo opj_decompress tiffdither gdaltindex opj_dump tiffdump gdaltransform osgeo4w-setup-work tiffinfo gdalwarp osgeo4w-setup tiffmedian gdal_contour pal2rgb tiffset gdal_grid portmap tiffsplit gdal_rasterize ppm2tiff w9xpopen gdal_translate proj xmlcatalog geod psql xmllint geotifcp python xxmklink gif2tiff pythonw gltpd ras2tiff epsg_tr gdalmove make-bat-for-py esri2wkt gdal_auth mkgraticule gcps2vec gdal_calc o-help gcps2wld gdal_edit o4w_env gdal2tiles gdal_fillnodata pct2rgb gdal2xyz gdal_merge rgb2pct gdalchksum gdal_polygonize setup-test gdalcompare gdal_proximity setup gdalident gdal_retile gdalimport gdal_sieveGDAL 1.11.2, released 2015/02/10C:\Users\maugust\Desktop>gdal2tiles.py C:\Users\maugust\Desktop\example_tifs\Pierce_2010_84.tif C:\Users\maugust\Desktop\example_tifs\tilegdalTraceback (most recent call last): File "C:\OSGeo4W\bin\gdal2tiles.py", line 2278, in gdal2tiles.process() File "C:\OSGeo4W\bin\gdal2tiles.py", line 482, in process self.open_input() File "C:\OSGeo4W\bin\gdal2tiles.py", line 856, in open_input self.out_ds.SetMetadataItem('NODATA_VALUES','%i %i %i' % (self.in_nodata[0],self.in_nodata[1],self.in_nodata[2]))IndexError: list index out of rangeC:\Users\maugust\Desktop>
