I am performing a an import on replica data using ArcObjects. Everything seems perfect - I am using one way Parent to Child with archiving enabled and I am using a disconnected approach (import XML from GeoDataserver). Also: we are using 10.1 with the latest service pack/QIP.
Nothing is throwing any errors, and all the data seems to have loaded correctly.
When I go to unregister replica (no longer needed), this also seems to process successfully (no errors or oddities just yet). But when I check inside the file geodatabase in ArcCatalog, it has created a mass of "ORG_" tables corresponding to tables that had undergone changes.
Poking around inside these tables, I see a lot of references to the data that seems to have been deleted or replaced (not the new data). Is this normal behavior? Are these just "original" records for reference? I am wondering why these were not cleaned up.
Any insight would be great, thanks!
