Here is the full code (i'll highlight the important parts after):
jQuery(document).ready(function($) {// =========================================================================================================================================// -----------------------------------------------------------------------------------------------------------------------------------------// DEFINE THE OPENLAYERS MAP// -----------------------------------------------------------------------------------------------------------------------------------------// ========================================================================================================================================= //var pathArray = window.location.href.split( '/' ); //var base_url = pathArray[0] + '://' + pathArray[2]; // Base URL (Modified by provisioning script) var base_url = 'http://192.168.111.222' // Set up URL's var arctic_wms = base_url.concat('/geoserver/arctic/wms'); var arctic_wfs = base_url.concat('/geoserver/arctic/wfs'); // User the OpenLayers ProxyHost OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url="; // Define OpenLayers click Control OpenLayers.Control.Click = OpenLayers.Class(OpenLayers.Control, { defaultHandlerOptions: { 'single': true, 'double': false, 'pixelTolerance': 0, 'stopSingle': false, 'stopDouble': false }, initialize: function(options) { this.handlerOptions = OpenLayers.Util.extend( {}, this.defaultHandlerOptions ); OpenLayers.Control.prototype.initialize.apply( this, arguments ); this.handler = new OpenLayers.Handler.Click( this, { 'click': this.trigger }, this.handlerOptions ); }, trigger: function(e) { var lonlat = map.getLonLatFromPixel(e.xy); // Create the json_string for frames/get/closest json_string = '{ "type": "Feature", "properties": { "location": "arctic", "x":' + lonlat.lon + ', "y": ' + lonlat.lat + ', "season_names": [ "" ] } }'; // Make the ajax call $.ajax({ url: base_url.concat('/ops/frames/get/closest'), type: "POST", data: ({app:'rds',data:json_string}), success: function(response){click_alert(response);}, error: function(){alert('Error creating popup');}}); } }); // DEFINE OpenLayers MAP Options var options = { maxExtent: new OpenLayers.Bounds(-1500000,-4000000,1500000,0), units: 'm', projection: "EPSG:3413", // Add controls to the map controls: [new OpenLayers.Control.Navigation(), new OpenLayers.Control.ZoomBox(), new OpenLayers.Control.PanZoomBar(), new OpenLayers.Control.MousePosition({prefix: '' +'EPSG:3413: '}), new OpenLayers.Control.ScaleLine(), new OpenLayers.Control.LayerSwitcher({'ascending':false})]}; // DEFINE MAP OBJECT AND POPUP VARIABLE var map = new OpenLayers.Map('map',options); // ADD AND ACTIVATE CLICK var click = new OpenLayers.Control.Click(); map.addControl(click); click.activate(); // DEFINE WMS LAYERS FOR MAP var grn_coast = new OpenLayers.Layer.WMS("Greenland Coastline",arctic_wms,{layers: 'arctic:greenland_coastline'}); var grn_nat_90 = new OpenLayers.Layer.WMS("Greenland Natural 90m",arctic_wms,{layers: 'arctic:greenland_natural_90m'}); var grn_bw_45 = new OpenLayers.Layer.WMS("Greenland BW 45m",arctic_wms,{layers: 'arctic:greenland_bw_45m'}); var rds_fl = new OpenLayers.Layer.WMS("Radar Depth Sounder Flightlines",arctic_wms,{layers: 'arctic:arctic_rds_line_paths',transparent:true,isBaseLayer:false}); var accum_fl = new OpenLayers.Layer.WMS("Accumulation Radar Flightlines",arctic_wms,{layers: 'arctic:arctic_accum_line_paths',transparent:true,isBaseLayer:false},{visibility:false}); var snow_fl = new OpenLayers.Layer.WMS("Snow Radar Flightlines",arctic_wms,{layers: 'arctic:arctic_snow_line_paths',transparent:true,isBaseLayer:false},{visibility:false}); var kuband_fl = new OpenLayers.Layer.WMS("KU Band Radar Flightlines",arctic_wms,{layers: 'arctic:arctic_kuband_line_paths',transparent:true,isBaseLayer:false},{visibility:false}); var polybound = new OpenLayers.Layer.Vector("Polygon Search Boundary",{'displayInLayerSwitcher':false}); var selectLine = new OpenLayers.Layer.Vector("Selected Line Vector",{'displayInLayerSwitcher':false}); // ADD DRAWING CONTROLS TO THE MAP drawControls = {polygon: new OpenLayers.Control.DrawFeature(polybound,OpenLayers.Handler.Polygon)}; for(var key in drawControls) {map.addControl(drawControls[key]);}; // STORE PROJ4 PROJECTIONS var wgs = new Proj4js.Proj('EPSG:4326'); var ups = new Proj4js.Proj('EPSG:3413'); // Deactivate drawing on double-click drawControls['polygon'].events.register("featureadded",' ',endDraw); function endDraw(data){ // Deactivate drawControls['polygon'].deactivate(); // Transform the polygon to WGS84 (EPSG:4326) var polybound_wgs = polybound.features[0].geometry.transform(new OpenLayers.Projection("EPSG:3413"),new OpenLayers.Projection("EPSG:4326")); // Get the extent/vertices of the polygon drawn var polyExt = polybound_wgs.getBounds(); var poly = polybound_wgs.getVertices(); // Set the coordinate boxes to the polygon bounds max_lat.value = polyExt.top; min_lat.value = polyExt.bottom; max_lon.value = polyExt.right; min_lon.value = polyExt.left; }; // Clear any polygons on re-activation of draw drawControls['polygon'].events.register("activate",' ',clearLayer); function clearLayer(data){polybound.removeAllFeatures();}; // ADD LAYERS TO MAP AND ZOOM TO MAP EXTENT map.addLayers([grn_coast,grn_nat_90,grn_bw_45,rds_fl,accum_fl,snow_fl,kuband_fl,polybound,selectLine]); map.zoomToMaxExtent();// =========================================================================================================================================// -----------------------------------------------------------------------------------------------------------------------------------------// TOOLS FOR THE BROWSER// -----------------------------------------------------------------------------------------------------------------------------------------// =========================================================================================================================================$('#draw_bound').click(function() { alert("POLYGON DRAWING INSTRUCTIONS:\n\nLeft-Click to add a vertex to your polygon.\nDouble-click to end drawing."); // Activate The Polygon Drawing Tool drawControls['polygon'].activate();});$('#clear_bound').click(function() { polybound.removeAllFeatures();});$('#clear_coords').click(function() { max_lat.value = ""; min_lat.value = ""; max_lon.value = ""; min_lon.value = "";});$('#clear_frame').click(function() { selectLine.removeAllFeatures(); if (typeof popup != 'undefined'){map.removePopup(popup);};});$('#get_csv').click(function() { document.getElementById("status").innerHTML = "STATUS: GENERATING CSV
"; // Check if max_lat,min_lat,max_lon,min_lon are empty if (max_lat.value == "" || min_lat.value == "" || max_lon.value == "" || min_lon.value == ""){ alert('Please enter coordinates or "Draw Boundary" to get CSV');document.getElementById("status").innerHTML = "STATUS: NORMAL
";} else{ alert('Your CSV is being generated. A download will pop-up when the file is ready. Make sure your pop-up blocker is disabled.'); // Construct the bound polygon 'POLYGON((min_lon min_lat,min_lon max_lat,max_lon max_lat,min_lon min_lat,min_lon min_lat))' var mla = min_lat.value; var mlo = min_lon.value; var mala = max_lat.value; var malo = max_lon.value; var bound_str = ("POLYGON(("+mlo+" "+mla+","+mlo+" "+mala+","+malo+" "+mala+","+malo+" "+mla+","+mlo+" "+mla+"))"); // Check if polygon string from draw exists (if so overwrite bound_str) if (typeof polybound_wgs != 'undefined' && polybound_wgs != ""){bound_str = polybound_wgs;}; // Construct JSON string var json_string = JSON.stringify({'bound':bound_str,location:'arctic'}); // Call the get csv django view and return the response $.ajax({ url: base_url.concat('/ops/layer_points/get/csv'), type: "POST", data: ({app:$('#system').val(),data:json_string}), success: function(response){csv_alert(response);}, error: function(){alert('Error creating CSV. Unknown Error.'); document.getElementById("status").innerHTML = "STATUS: NORMAL
";}}); };});function csv_alert(response){ if (response.status == 0) {alert(response.data); document.getElementById("status").innerHTML = "STATUS: NORMAL
"; return;}; alert('Your CSV is ready for download, a new window will open. Please save the link, your csv will be available on the server for 7 days.'); document.getElementById("status").innerHTML = "STATUS: NORMAL
"; return window.open(response.data,'CSV Download Ready','width=600,height=200');}function click_alert(response){ // Clear the previously selected line selectLine.removeAllFeatures(); // Clear any existing popups if (typeof popup != 'undefined'){map.removePopup(popup);}; // Parse the response from django data = jQuery.parseJSON(response.data); // Create the vector feature and plot the vector var points = new Array(); for (idx=0;idx 90){alert("Latitude must be between -90 and 90")};});$('#min_lat').blur(function() { if (min_lat.value < -90){alert("Latitude must be between -90 and 90")};});$('#min_lon').blur(function() { if (min_lon.value < -180){alert("Longitude must be between -180 and 180")};});$('#max_lon').blur(function() { if (max_lon.value > 180){alert("Longitude must be between -180 and 180")};});});So I have a button on an html page that activates the drawing of a polygon on a vector layer. When a feature is added the drawing is halted. When the buttom to draw is clicked again the features are removed, and the cycle starts over.
Here is the layer:
var polybound = new OpenLayers.Layer.Vector("Polygon Search Boundary" {'displayInLayerSwitcher':false});Here is adding the drawing controls:
drawControls = {polygon: new OpenLayers.Control.DrawFeature(polybound,OpenLayers.Handler.Polygon)};for(var key in drawControls) {map.addControl(drawControls[key]);};Here is the function that activates drawing:
$('#draw_bound').click(function() { alert("POLYGON DRAWING INSTRUCTIONS:\n\nLeft-Click to add a vertex to your polygon.\nDouble-click to end drawing."); // Activate The Polygon Drawing Tool drawControls['polygon'].activate();});This clears any existing features on activation:
// Clear any polygons on re-activation of drawdrawControls['polygon'].events.register("activate",' ',clearLayer); function clearLayer(data){polybound.removeAllFeatures();};What happens that I cannot figure out is this:
Here is the layer:
- User clicks the draw button and draws a polygon
- User double clicks and drawing is finished, all is well
- ERROR HERE: User zooms in/out or uncheks-rechecks the layer in the layer switcher and the polygon they drew disappears. The object still exists, it's just not visible.
