OpenLayers-3 setting zoom so layers fit in map window
Is there a way to dynamically set the zoom level so that the current layers always fit within the width of the map frame on page load?
Currently the zoom level is set statically such that when using a full resolution monitor the application loads perfectly the entirety of the map fits but when loading the map at a lower resolution the map loads at the same zoom level but features are cut off.
