OpenLayers 3 how can I get the current center of the view?
I would like the get the center (coordinates) of the current view. I need it for the geoserver print modul.I've found the following code:
var center= ol.extent.getCenter({});
But it unfortunately doesnt work. Furthermore I've found a code in the API (getview.getcenter()), but its only shows the initial center, and it is not changing when i explore on the map.
Thank you for the help!
