Using OpenLayers 3, I cannot get this message to go away:
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at http://myserver:8085/geoserver/sf/o...Name=sf:view1&maxFeatures=1&outputFormat=JSON. This can be fixed by moving the resource to the same domain or enabling CORS.This is the code:
// Ol3 only supports Projections "EPSG:4326" and "EPSG:3857". For every other projection you need proj4js proj4.defs("EPSG:2236", "+proj=tmerc +lat_0=24.33333333333333 +lon_0=-81 +k=0.999941177 +x_0=200000.0001016002 +y_0=0 +ellps=GRS80 +towgs84=0,0,0,0,0,0,0 +units=us-ft +no_defs"); // Leases Layer var myLayer = new ol.layer.Vector({ source: new ol.source.GeoJSON({ projection: 'EPSG:2236', url: 'http://myserver:8085/geoserver/sf/ows?service=WFS&version=1.0.0&request=GetFeature&typeName=sf:view1&maxFeatures=1&outputFormat=JSON', crossOrigin: null }) });// View var view = new ol.View({ projection: 'EPSG:2236', center: [0, 0], zoom: 4 }); // Map var map = new ol.Map({ target: 'map', renderer: 'canvas', layers: [myLayer], view: view });I have tried setting the crossOrigin setting to:
crossOrigin: nullcrossOrigin: 'null'crossOrigin: 'anonymous'I only see the zoom in/out control but the layer is not rendered. Any help would be appreciated.
Update #1:
I went with simon's option 3 below. I enabled CORS in GeoServer by copying the necessary jetty-servlets jar files and enabling it in the \WEB-INF\web.xml:
cross-origin org.eclipse.jetty.servlets.CrossOriginFilter allowedOrigins * allowedMethods * allowedHeaders * cross-origin /*After I did that, I tested the page again and receive the same error:
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at http://myserver:8085/geoserver/sf/o...Name=sf:view1&maxFeatures=1&outputFormat=JSON. This can be fixed by moving the resource to the same domain or enabling CORS.Looks like I am still missing something. Do I have to do anything from the OpenLayers Side? Thanks.
Update # 2
I ended up getting rid of Jetty and uninstalling GeoServer completely. The problem is when you install the geoserver windows installer, it installs a version of jetty that is 4 years old! (Jetty version 6.1.8) Even though I had copied the jar files for CORS, it is only supported in Jetty 7+.
I found out that you can install a WAR file. I decided to use Tomcat since that is what GeoServer is mostly tested on according to this note from the GeoServer website:
Note GeoServer has been mostly tested using Tomcat, and therefore these instructions may not work with other container applications.
These are the instructions for installing the WAR file:
http://docs.geoserver.org/stable/en/user/installation/war.html
This is a nice how-to video also:
https://www.youtube.com/watch?v=YEOA8WWWVCw
After you complete the install, you then enable CORS:
http://enable-cors.org/server_tomcat.html
Update #1:
Update # 2
