I am involved in developing a Android application that needs to be able to make use of Esri Shapefiles. Hardware used will be 7" Android rugged tablets running Android 4.2 or later. It is an offline application, the shapefiles gets loaded onto the device’s SD Card. The application would show a map with shapes representing different premises that needs to be audited. The user would then click on a shape representing the premises and I need to get the data for to the clicked shape to identify which premises is being audited. I also need to make sure that the user’s current position falls within the boundaries of the shape. The user will only pan and zoom on the map. Map needs to be centred on the users current position and the current position needs to be indicated. Audit data is synced via Wi-Fi once the user is back at the office as mobile carrier coverage is poor in some of the areas.
Please recommend a free/open source library with which this can be accomplished.
