Open Layers 3 Dynamically Add Layer from folder contents
I am new to Open Layers and have searched far and wide trying to figure out how to programmatically add layers with a default set of parameters from a selected source path, but Google has not produced any meaningful results (at least that I can identify).
I have generated a set of thumbnails to represent each map layer using C# from image files, which I want to use to provide a clickable element that adds the layer to the OL3 map to view/manipulate by the user. The images are dynamically generated, so ideally I want to create a dynamic element (via ASP, JS, or something else) that will feed a full sized image to the map layer. As I see it, it could be done by dynamically changing the URL parameter for a map layer, or adding a whole new layer for each click event on an image. Has anyone tried to do this, or something similar? Perhaps there is a better way to serve images to layers from a folder structure?
