ogr2ogr conversion error - Can't create fields of type Binary on shapefile layers
I'm having trouble using the ogr2ogr tool on the command line. My data is stored in SQL as binary, type is mixed polygons and multipolygons. I am using the following command for conversion from SQL to shapefile:
ogr2ogr -f "ESRI Shapefile" "H:\PolandSQLQuery\test_shp\test3.shp" "ODBC:USERNAME/PW@SERVERNAME" -sql "SELECT TOP 1 ID, GEOMETRY::STGeomFromWKB([polygon].STAsBinary(),4326) FROM [eQUIP75CEEFloodCzechRepublic].[dbo].[CZ_Hist2002_3308238]" -overwrite -nlt POLYGON -a_srs "EPSG:4326"My error message is:
ERROR 6: Can't create fields of type Binary on shapefile layers.I have tried numerous things, such as STGeomFromText and .ToString() conversion et al. I am using GDAL 1.11.1 (2014/09/24) with the newest MS SQL driver.
Any ideas?
