Obtaining extent of each polygon in shapefile using ArcPy?
In arcgis 10 and python I want to get the extent (xmax, ymax, xmin, ymin) info of each of the polygons in a shape file.
I can get the extent of the whole shape file using
file=r"D:\SCRATCH\ARCGIS\100k_trc_tiles_TVM.shp"desc=arcpy.Describe(file)print desc.extent.Xmax
394551.52085039532
But I can't seem to figure out how to get the same info for each row in the dataset.
rows = arcpy.SearchCursor("100k_trc_tiles_TVM")for row in rows: print rowprints the 31 rows in the dataset but
for row in rows: desc=arcpy.Describe(row) print desc.extent.Xmaxgives an error.
Runtime error : Object: Describe input value is not valid type
I was thinking of adding the extent values to the table using "calculate geometry" but this only gives the centroid. Then I guess we can use something like row.GetValue("xmax").
That being said I know that we can create the X/Y, max/min using the function from http://www.ian-ko.com/free/free_arcgis.htm but it would be best if we can avoid having to add fields, especially if arcpy can get these values.
Basically I need to get the extents to feed into the clip tool to clip out 30 areas of data (according to the 1:100,000 map sheets) for geoprocessing since the Split tool fails due to the large size of the dataset (see Issues with large datasets). I want to automate this as it is repeated on a number of datasets.
=== working script ===
# Emulates Arc Info SPLIT tool by using Clip but# Requires a FC from which each row is used as the input clip feature.# Each row must be rectangular.# Used on 12GB FGDB with 100 million records.#Licence: Creative Commons#Created by: George Corea; georgec@atgis.com.au, coreagc@gmail.comimport arcpy, string#inFrame=arcpy.GetParameterAsText(0) # Input dataframe FC#inFile=arcpy.GetParameterAsText(1) # Input FC for splitting#outDir=arcpy.GetParameterAsText(2) # Output FGDBinFrame=r"D:\SCRATCH\ARCGIS\100k_trc_tiles_TVM.shp"inFile=r"c:\junk\106\data\7_Merge.gdb\FullRez_m2b"outDir=r"D:\SCRATCH\Projects\206\datasplit\test_slaasp.gdb"#NameField="Name_1"#arcpy.env.workspace = r"C:/Workspace"arcpy.env.overwriteOutput = Truerows = arcpy.SearchCursor(inFrame)shapeName = arcpy.Describe(inFrame).shapeFieldNamefor row in rows: feat = row.getValue(shapeName) Name = row.Name_1 print "Executing clip on: "+str(Name) extent = feat.extent #print extent.XMin,extent.YMin,extent.XMax,extent.YMax# Create an in_memory polygon XMAX = extent.XMax XMIN = extent.XMin YMAX = extent.YMax YMIN = extent.YMin pnt1 = arcpy.Point(XMIN, YMIN) pnt2 = arcpy.Point(XMIN, YMAX) pnt3 = arcpy.Point(XMAX, YMAX) pnt4 = arcpy.Point(XMAX, YMIN) array = arcpy.Array() array.add(pnt1) array.add(pnt2) array.add(pnt3) array.add(pnt4) array.add(pnt1) polygon = arcpy.Polygon(array) ShapeFile = outDir+"\\temp_poly" arcpy.CopyFeatures_management(polygon, ShapeFile) #print Name### Set local variables in_features = inFile clip_features = ShapeFile out_feature_class = outDir+"\\"+Name xy_tolerance = "0.22" # Execute Clip try: arcpy.Clip_analysis(in_features, clip_features, out_feature_class, xy_tolerance) print "Completed: "+str(Name) except: error = arcpy.GetMessages() print "Failed on: "+str(Name)+" due to "+str(error)
