I am writing a console application using ArcGIS (engine or desktop). I'm trying to rotate and scale a map based on a polygon, and I'm not having any luck at all. With some tinkering, I can usually do one or the other but not both.
Anybody have any suggestions? I feel as though I've tried every variation in terms of rotating the map and adjusting the scale either using the Imap interface, or the IActiveView interface.
Private Sub Zoom2AndExportJpgs(mapDocument As IMapDocument, imagePath As String) 'Get the relevant strip maps for the route Dim map As IMap = mapDocument.Map(0) '(assumed that there is only one map in the mxd) Dim pageLayout As IPageLayout = mapDocument.PageLayout Dim pageAV As IActiveView = pageLayout Dim mapAV As IActiveView = map Try 'get a list of strip map objects... EF object containing a list of the 4 corners of a polygon Dim stripmaps As List(Of MRLAStripMapExtent) = getStripMaps() Dim filename As String = "" 'get all the associated stripmaps for the route for each scale If Not stripmaps Is Nothing Then For i = 0 To stripmaps.Count - 1 Dim pgon As IPolygon = geometryHelper.CreatePGON(stripmaps(i).RectLowerLeftX, stripmaps(i).RectLowerLeftY, _ stripmaps(i).RectLowerRightX, stripmaps(i).RectLowerRightY, _ stripmaps(i).RectUpperLeftX, stripmaps(i).RectUpperLeftY, _ stripmaps(i).RectUpperRightX, stripmaps(i).RectUpperRightY) filename = imagePath & stripmaps(i).ZoomScale & stripmaps(i).PageNumber & ".jpg" CreateJpgFile(filename, mapAV, pageAV, pgon, stripmaps(i).ANGLE, stripmaps(i).ZoomScale) Next i End If Catch ex As Exception publishError.PublishError(publishError.ErrorSeverity.majorStopRouteProcessing, ex) End TryEnd SubPrivate Sub CreateJpgFile(ByVal sFilename As String, ByVal pAV As ESRI.ArcGIS.Carto.IActiveView, _ ByVal pPageActiveView As ESRI.ArcGIS.Carto.IActiveView, _ ByVal pgon As IPolygon, rotationAngle As Double, _ mapScale As Double) Dim pExport As ESRI.ArcGIS.Output.IExport pExport = New ESRI.ArcGIS.Output.ExportJPEG pAV.Extent = pgon.Envelope pAV.ScreenDisplay.DisplayTransformation.ScaleRatio = mapScale pAV.ScreenDisplay.DisplayTransformation.Rotation = rotationAngle '0 pAV.Refresh() 'Export Image.... pExport.ExportFileName = sFilename pExport.Resolution = 96 Dim exportRECT As ESRI.ArcGIS.esriSystem.tagRECT exportRECT = pPageActiveView.ExportFrame Dim pPixelBoundsEnv As ESRI.ArcGIS.Geometry.IEnvelope pPixelBoundsEnv = New ESRI.ArcGIS.Geometry.Envelope pPixelBoundsEnv.PutCoords(exportRECT.left, exportRECT.bottom, exportRECT.right, exportRECT.top) pExport.PixelBounds = pPixelBoundsEnv Dim hDC As Integer hDC = pExport.StartExporting pPageActiveView.Output(hDC, pExport.Resolution, exportRECT, Nothing, Nothing) 'Finish writing the export file and cleanup any intermediate files. pExport.FinishExporting() pExport.Cleanup()End Sub
