The Problem:
I've installed Nominatim on CentOS 7, but I'm running into an import error when I try to load the data. Here is the error:
Import Please download and build osm2pgsql. If it is already installed, check the path in your local settings (settings/local.php) file. ERROR: osm2pgsql not found in '/opt/Nominatim/osm2pgsql/osm2pgsql' osm2pgsql not found in '/opt/Nominatim/osm2pgsql/osm2pgsql' Osm2pgsql is already installed and here are the following paths after I run some find commands:
/usr/local/bin/osm2pgsql /usr/local/share/osm2pgsql I've tried specifying these paths in the local.php file like this:
@define('CONST_Osm2pgsql', '/usr/local/bin/osm2pgsql'); @define('CONST_Osm2pgsql', '/usr/local/share/osm2pgsql'); Unfortunately, I still get the same problem, so I must not be specifying the paths right. Does anyone know the syntax of local.php? There aren't any guides I could find online beyond basic postgresql and postgis configurations.
