Am trying to expose a vector layer (loaded from shape file into PostGIS) as a WFS layer using tinyows.
Following the instructions in the mapserver/tinyows documentation, here is the .map file I have come up with so far:
MAP NAME "world" CONFIG "MS_ERRORFILE" "/home/balajeerc/Projects/Build_Dir/myproject/data/logs/mapservice_errors.log" EXTENT -180.000 -90.000 180.000 90.000 WEB METADATA "tinyows_schema_dir" "/home/balajeerc/Projects/Build_Dir/myproject/deps/mygis-services-0.1/data/schema" "tinyows_onlineresource" "http://192.168.43.164:19090/vectors/world/wfs?" "wfs_title" "MyGIS Feature Service: World" "wfs_contact" "support@giscompany.com" "wms_title" "MyGIS Feature Service: World" "wms_srs" "epsg:4326" "wms_enable_request" "*" "log_level" "15" "log" "/home/balajeerc/Projects/Build_Dir/myproject/deps/mygis-services-0.1/data/logs/wfs_world.log" "ows_contactorganization" "GeorbisServer" "ows_contactelectronicmailaddress" "contact@giscompany.com" "ows_contactperson" "Balajee.R.C" END END PROJECTION "init=epsg:4326" END LAYER NAME 'world_boundaries' CONNECTIONTYPE postgis CONNECTION "host=localhost user=mygis password=asdf123 dbname=mygis port=19095" DATA "geom from world_boundaries" TYPE POLYGON METADATA 'wfs_title' 'world_boundaries' 'wfs_namespace_prefix' 'tows' 'wfs_namespace_uri' 'http://www.giscompany.com/' 'wfs_srs' 'epsg:4326' 'wms_srs' 'epsg:4326' 'wms_title' 'world_boundaries' 'tinyows_table' 'world_boundaries' 'tinyows_writable' '1' 'tinyows_retrievable' '1' END CLASS STYLE COLOR 128 128 128 ANTIALIAS true END END PROJECTION "init=epsg:4326" END DUMP TRUE ENDENDThis .map file works fine with mapserver, i.e. I am able to render the feature layer as a WMS service using QGIS as a client.
However, the WFS service (served by tinyows) using the same file (set using TINYOWS_MAPFILE environment variable seems to show no layers in GetCapabilities (and hence QGIS is not able to load any).
The output from tinyows --check is as follows:
balajeerc@Balajee:~/Projects/tinyows-1.1.1$ ./tinyows --checkTinyOWS version: 1.1.0FCGI support: YesConfig File Path: /home/balajeerc/Projects/Build_Dir/myproject/data/service_data/data/wfs/world.map (Mapfile)PostGIS Version: 2.1.8PostGIS dsn: host=localhost user=mygis password=asdf123 dbname=mygis port=19095Output Encoding: UTF-8Database Encoding: UTF8Schema dir: /home/balajeerc/Projects/Build_Dir/myproject/deps/mygis-services-0.1/data/schemaDisplay bbox: YesEstimated extent: NoCheck schema: YesCheck valid geoms: YesAvailable layers:balajeerc@Balajee:~/Projects/tinyows-1.1.1$ Note that even though I am using a 1.1.1 version of tinyows, it prints tinyows version as 1.1.0. Also note that it prints no layers.
Wondering what is going wrong, I decided to step into the code. I recompiled code after turning off (-O2) optimizations and with debugging (-g) enabled.
I am only able to get so far as the ows_parse_config method in src/ows/ows_config.c. I am, for some reason not able to step into ows_parse_config_map in src/mapfile/mapfile.c. This probably has something to do with the fact that mapfile.c is generated by flex using src/map/mapfile.l.
At this point I am completely stuck and at a brick wall as to what might be going wrong. Can someone here please help?
