I have the following map:https://aressk.cartodb.com/viz/408dd3ea-deea-11e4-9d17-0e9d821ea90d/embed_map
It has two layers.
On the Waypoints layer, I have Hover turned on for the Info Window.
On the SPOT Tracker layer, I have Click turned on for the Info Window.
The hover for the Waypoints works, but the problem is that if I hover over points from the SPOT Tracker layer I get a "No data available" message that I don't want.
If I turn off Hover on the Waypoints layer, the "No data available" will not appear when hovering over a point from the SPOT layer.
Any suggestions on how I can remove the "No data available" message?
It has two layers.
