Need help with a spatial join problem in ArcGIS
I am wondering if anyone can help me with this problem. I have two spatial layers of about the same (not exactly same) spatial extent. Layer#1 has about twice the number of polygons than layer#2 (in thousands). I am trying to calculate values for Field#X and Field#Y present in layer#2 for layer#1 based on spatial location (using right click -> joins ans relate etc..). What would be the best way to do it? I am trying to do it using "join data from one layer based on spatial location" and then averaging. But once I sum up the total for Field#X and Field#Y for the resulting layer, it is a much different than the total for the same in the original layer (i.e. layer#2). It should be comparable as the spatial extents are about the same. Any suggestions on how to address this?
