In the image given below, solid lines are showing as road elements and points are showing as data collected for those road segments. I want to update road element id to the points shapefile. "Near" tool of ArcMap has almost solved this problem except for the points lying in red region (marked in the image) which is obvious as per the algorithm of this tool. In this red region, "Near" tool updates the id of BE road element but I want to update the id of AB and BC road elements respectively because those points belong to AB and BC road elements.
