def initGui(self): """Create the menu entries and toolbar icons inside the QGIS GUI."""
icon_path = ':/plugins/cropEt/icon.png' self.add_action( icon_path, text=self.tr(u'links crop et'), callback=self.run, parent=self.iface.mainWindow()) # connect our select function to the canvasClicked signal result = self.clickTool.canvasClicked.connect(self.selectFeature) QMessageBox.information( self.iface.mainWindow(),"Info", "connect = %s"%str(result) )def unload(self): """Removes the plugin menu item and icon from QGIS GUI.""" for action in self.actions: self.iface.removePluginMenu( self.tr(u'&Testlink'), action) self.iface.removeToolBarIcon(action) # remove the toolbar del self.toolbardef handleMouseDown(self, point, button): #QMessageBox.information( self.iface.mainWindow(),"Info", "X,Y = %s,%s" % (str(point.x()),str(point.y())) ) self.dlg.clearTextBrowser() self.dlg.setTextBrowser( str(point.x()) + " , " +str(point.y()) )def selectFeature(self, point, button): layer = self.iface.addVectorLayer("D:/python/cropped_area.shp", "sample_cropped area","ogr") selectList = [] if layer: for feature in layer.getFeatures(): # fetch geometry geom = feature.geometry() print "Feature ID %d: " % feature.id() layer.setSelectedFeatures(selectList) # show some information about the feature #if geom.type() == QGis.Point: #x = geom.asPoint() #print "Point: " + str(x) #elif geom.type() == QGis.Line: # x = geom.asPolyline() # print "Line: %d points" % len(x) #if geom.type() == QGis.Polygon: #x = geom.asPolygon() #numPts = 0 #for ring in x: #numPts += len(ring) #print "Polygon: %d rings with %d points" % (len(x), numPts) #else: #print "Unknown" # fetch attributes attrs = feature.attributes() #if attrs==row[0].strip(): #selection.append(feature.id()) # attrs is a list. It contains all the attribute values of this feature print attrs #layer.setSelectedFeatures(selection) if not layer: print "Layer failed to load!" QMessageBox.information( self.iface.mainWindow(),"Info", "Click on the feature to select" ) #else: # QMessageBox.information( self.iface.mainWindow(),"Info", "No layer currently selected in TOC" )I want to load a shape file and want to display the properties like feature count, attribute table list in qgis interface plugin.Accordingly wrote the code;a portion is attached..But, on each mouse click, a new layer is getting created and no feature property is displayed even after removing the commented statementsCan anyone suggest the error?
