I am trying to create a model that will select each feature within a feature class, then perform an intersect between that selection and another layer. The model setup seems rather straightforward, but I run into a problem with the output file name. I want the file name to be the same as the input for the selected layer (the one on which I am performing the iteration), so I originally tried %NAME%; however, this function is supposed to cause it to be named after the input file and in this case, there are two inputs since I performing an intersect.
Here is the model I have drafted below for clarity. I want to select each feature in Main_Lanes separately and intersect it with the Seg1_WZ layer to get an ouput point intersect named after the Main_Lanes selected feature.
