Model Builder, which tool should I use to rename layers with value from table
Hi I have a model bulder tool with an iterator that splits a feature into multiple shapefiles based on a attribute field. The problem I'm running into is instead of simply using the number values for naming, I would like to replace the number with what the layer physically represents. For example a few of the new shapefiles are
M4ExportLine_Layer149.shp
M4ExportLine_Layer150.shp
M4ExportLine_Layer153.shp
I would like these to be named respectively
M4ExportLine_LayerBuriedFiber.shp
M4ExportLine_LayerAerialFiber.shp
M4ExportLine_LayerOverlashFiber.shp
And there are quite a few more that need renamed in that fashion. The problem is there is only layer numbers in the attribute table and nothing represents the physical name except for the legend. Here is the model I have so far [Model][1]
