Is there an issue with the SAGA-tool "Mosaicking rasters"?I tried it with different rasters. In Sage itself it works fine.
Algorithmus Mosaick raster layers startet... io_gdal 0 -TRANSFORM -INTERPOL 0 -GRIDS "C:\Temp\processing\04593242dc054133b9fbcae916bae1f8\1tif.sgrd" -FILES "C:\Temp\test\2.tif,C:\Temp\test\1.tif" grid_tools "Mosaicking" -TARGET 0 -GRIDS "C:\Temp\processing\04593242dc054133b9fbcae916bae1f8\1tif.sgrd" -TYPE 7 -INTERPOL 0 -OVERLAP 1 -BLEND_DIST 10 -MATCH 0 -USER_FIT 0 -USER_XMIN 331858.3 -USER_XMAX 335568.9 -USER_YMIN 5921607.7 -USER_YMAX 5924629.6 -USER_GRID "C:\Temp\processing\0aab6cedcd08418eab5e1ee4eca47901\USERGRID.sdat" C:\PROGRA~1\QGISPI~1\bin>set SAGA=C:\Program Files\QGIS Pisa\apps\saga C:\PROGRA~1\QGISPI~1\bin>set SAGA_MLB=C:\Program Files\QGIS Pisa\apps\saga\modules C:\PROGRA~1\QGISPI~1\bin>PATH=PATH;C:\Program Files\QGIS Pisa\apps\saga;C:\Program Files\QGIS Pisa\apps\saga\modules C:\PROGRA~1\QGISPI~1\bin>saga_cmd io_gdal 0 -TRANSFORM -INTERPOL 0 -GRIDS "C:\Temp\processing\04593242dc054133b9fbcae916bae1f8\1tif.sgrd" -FILES "C:\Temp\test\2.tif,C:\Temp\test\1.tif" ERROR 1: Can't load requested DLL: C:\Program Files\QGIS Pisa\apps\saga\dll\gdal_MrSID.dll 127: Die angegebene Prozedur wurde nicht gefunden. ERROR 1: Can't load requested DLL: C:\Program Files\QGIS Pisa\apps\saga\dll\gdal_MrSID.dll 127: Die angegebene Prozedur wurde nicht gefunden. ERROR 4: C:\Temp\test\2.tif,C:\Temp\test\1.tif' does not exist in the file system, and is not recognised as a supported dataset name. library path: C:\Program Files\QGIS Pisa\apps\saga\modules\io_gdal.dll library name: Import/Export - GDAL/OGR tool name : GDAL: Import Raster author : O.Conrad (c) 2007 A.Ringeler) Parameters Grids: No objects Files: "C:\Temp\test\2.tif,C:\Temp\test\1.tif" Transformation: yes Interpolation: Nearest Neighbor loading: C:\Temp\test\2.tif,C:\Temp\test\1.tif failed: could not find a suitable import driver Error: Dataset creation failed:C:\Temp\test\2.tif,C:\Temp\test\1.tif' does not exist in the file system, and is not recognised as a supported dataset name. Error: executing tool [GDAL: Import Raster] C:\PROGRA~1\QGISPI~1\bin>saga_cmd grid_tools "Mosaicking" -TARGET 0 -GRIDS "C:\Temp\processing\04593242dc054133b9fbcae916bae1f8\1tif.sgrd" -TYPE 7 -INTERPOL 0 -OVERLAP 1 -BLEND_DIST 10 -MATCH 0 -USER_FIT 0 -USER_XMIN 331858.3 -USER_XMAX 335568.9 -USER_YMIN 5921607.7 -USER_YMAX 5924629.6 -USER_GRID "C:\Temp\processing\0aab6cedcd08418eab5e1ee4eca47901\USERGRID.sdat" ERROR 1: Can't load requested DLL: C:\Program Files\QGIS Pisa\apps\saga\dll\gdal_MrSID.dll 127: Die angegebene Prozedur wurde nicht gefunden. ERROR 1: Can't load requested DLL: C:\Program Files\QGIS Pisa\apps\saga\dll\gdal_MrSID.dll 127: Die angegebene Prozedur wurde nicht gefunden. library path: C:\Program Files\QGIS Pisa\apps\saga\modules\grid_tools.dll library name: Grid - Tools tool name : Mosaicking author : O.Conrad (c) 2003-12 Load grid: C:\Temp\processing\04593242dc054133b9fbcae916bae1f8\1tif.sgrd... failed Mosaicking: could not initialize data objects Error: Grid file could not be opened. Error: executing tool [Mosaicking] C:\PROGRA~1\QGISPI~1\bin>exit Converting outputs Lade Ergebnis Layer
