Merge layers (SAGA) ERROR
with QGIS 2.10 it is not possible to merge vector layers with the "Processing-Saga" tool (merge layers). The following error log comes up:
Algorithmus Merge layers startet... shapes_tools "Merge Layers" -INPUT "C:\Temp\convexhull2\hull2.shp,C:\Temp\convexhull2\hull3.shp,C:\Temp\convexhull2\hull4.shp" -SRCINFO -MATCH -MERGED "C:\Temp\processing\merge.shp" C:\PROGRA~1\QGISPI~1\bin>set SAGA=C:/PROGRA~1/QGISPI~1/apps\saga C:\PROGRA~1\QGISPI~1\bin>set SAGA_MLB=C:/PROGRA~1/QGISPI~1/apps\saga\modules C:\PROGRA~1\QGISPI~1\bin>PATH=PATH;C:/PROGRA~1/QGISPI~1/apps\saga;C:/PROGRA~1/QGISPI~1/apps\saga\modules C:\PROGRA~1\QGISPI~1\bin>saga_cmd shapes_tools "Merge Layers" -INPUT "C:\Temp\convexhull2\hull2.shp,C:\Temp\convexhull2\hull3.shp,C:\Temp\convexhull2\hull4.shp" -SRCINFO -MATCH -MERGED "C:\Temp\processing\merge.shp" ERROR 1: Can't load requested DLL: C:\PROGRA~1\QGISPI~1\apps\saga\dll\gdal_MrSID.dll 127: Die angegebene Prozedur wurde nicht gefunden. ERROR 1: Can't load requested DLL: C:\PROGRA~1\QGISPI~1\apps\saga\dll\gdal_MrSID.dll 127: Die angegebene Prozedur wurde nicht gefunden. library path: C:\PROGRA~1\QGISPI~1\apps\saga\modules\shapes_tools.dll library name: Shapes - Tools tool name : Merge Layers author : V.Olaya (c) 2004 Load shapes: C:\Temp\convexhull2\hull2.shp,C:\Temp\convexhull2\hull3.shp,C:\Temp\convexhull2\hull4.shp... Parameters Layers: 1 object (hull4) Merged Layer: Merged Layer Add Source Information: yes Match Fields by Name: yes Error: Nothing to do! Merging needs more than one input data set. Error: executing tool [Merge Layers] C:\PROGRA~1\QGISPI~1\bin>exit
