MapServer map file shows Raster image as white
I'm using PAN image for raster publishing but the output in browser shows a full white image? Please give me the solution?My map file is ass follows:
MAPNAME "terra"# Map image sizeSIZE 600 600UNITS ddEXTENT 77.0962025047 23.8718740333 84.6389301196 30.4075924299 PROJECTION 'proj=longlat' 'ellps=WGS84' 'datum=WGS84' 'no_defs' END # Background color for the map canvas -- change as desired IMAGECOLOR 155 155 155 IMAGEQUALITY 95 IMAGETYPE png OUTPUTFORMAT NAME png DRIVER 'GD/PNG' MIMETYPE 'image/png' IMAGEMODE RGBA EXTENSION 'png' END # Legend LEGEND IMAGECOLOR 255 255 255 STATUS ON KEYSIZE 18 12 LABEL TYPE BITMAP SIZE MEDIUM COLOR 0 0 0 END END # Web interface definition. Only the template parameter # is required to display a map. See MapServer documentation WEB # Set IMAGEPATH to the path where MapServer should # write its output. IMAGEPATH "../tmp" # Set IMAGEURL to the url that points to IMAGEPATH # as defined in your web server configuration IMAGEPATH "../tmp" # WMS server settings METADATA 'wms_title' 'terra' 'wms_onlineresource' 'http://my.host.com/cgi-bin/mapserv?map=wms.map&' 'wms_srs' 'EPSG:4326' END #Scale range at which web interface will operate # Template and header/footer settings # Only the template parameter is required to display a map. See MapServer documentation END LAYER NAME "UPC1PAN10SISDP2012" TYPE RASTER OFFSITE 0 0 0 DATA 'Z:\Rasters\10K\10D\UP\UPC1PAN10SISDP2012.img ' METADATA 'wms_title' 'UPC1PAN10SISDP2012' 'WMS_ENABLE_REQUEST' '*' END STATUS DEFAULT TRANSPARENCY 100 PROJECTION 'proj=longlat' 'ellps=WGS84' 'datum=WGS84' 'no_defs' '' END ENDEND
