Mapserver - Image Dimensions Don't Match WMS Parameters
Here is the .map file I am using for a simple map with one layer showing the blue marble world:
MAP NAME "world" CONFIG "MS_ERRORFILE" "/home/balajeerc/Projects/gis_project_Build_Dir/gis_project/data/logs/mapservice_errors.log" CONFIG "PROJ_LIB" "/home/balajeerc/Projects/gis_project_Build_Dir/gis_project/deps/proj.4-master/share/proj" CONFIG "ON_MISSING_DATA" "LOG" DEBUG 5 EXTENT -180.000 -90.000 180.000 90.000 SHAPEPATH "/home/balajeerc/Projects/gis_project_Build_Dir/gis_project/data/service_data/data/wms" IMAGECOLOR 255 255 255 SIZE 1350 675 WEB METADATA "wms_title" "Georbis WMS Server" "wms_author" "MyCompany" "wms_onlineresource" "http://10.0.0.8:19090/rasters/world/wms?" "wms_enable_request" "*" "wms_srs" "epsg:4326 epsg:3857" "wms_feature_info_mime_type" "text/html" "wms_format" "image/jpg" END END PROJECTION "init=epsg:4326" END LAYER NAME world TYPE RASTER DATA "world.tif" EXTENT -180.000 -90.000 180.000 90.000 METADATA "wms_title" "BlueWorld Map" "wms_srs" "epsg:4326 epsg:3857" "wms_server_version" "1.1.1" END PROJECTION "init=epsg:4326" END END END Here is the WMS request I am making to the server:
http://localhost:19090/rasters/worl...21379768,8834897.477313813,-7592337.145509986 The trouble is that even though I specify a width and height of 696 and 872 respectively, I always get an image with the original image dimensions, i.e. 1350 x 675.
Why is this the case? Like other WMS servers, I am hoping that Mapserver will also scale the base layer into the resolution I am requesting from it.
