Maperitive won't open on my Mac... I get this error message instead
Is there anyone who can tell me what's going on here? When I enter "mono Maperitive.exe" in the Terminal, I get this:
Unhandled Exception:System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.KnownColors ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.GDIPlus ---> System.DllNotFoundException: /Library/Frameworks/Mono.framework/Versions/3.12.1/lib/libgdiplus.dylib at (wrapper managed-to-native) System.Drawing.GDIPlus:GdiplusStartup (ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&) at System.Drawing.GDIPlus..cctor () [0x00000] in :0 --- End of inner exception stack trace --- at System.Drawing.KnownColors..cctor () [0x00000] in :0 --- End of inner exception stack trace --- at System.Drawing.SystemColors.get_ControlLightLight () [0x00000] in :0 at Deska.Theming.Theme..ctor () [0x00000] in :0 at (wrapper managed-to-native) System.Reflection.MonoCMethod:InternalInvoke (System.Reflection.MonoCMethod,object,object[],System.Exception&) at System.Reflection.MonoCMethod.InternalInvoke (System.Object obj, System.Object[] parameters) [0x00000] in :0 [ERROR] FATAL UNHANDLED EXCEPTION: System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.KnownColors ---> System.TypeInitializationException: An exception was thrown by the type initializer for System.Drawing.GDIPlus ---> System.DllNotFoundException: /Library/Frameworks/Mono.framework/Versions/3.12.1/lib/libgdiplus.dylib at (wrapper managed-to-native) System.Drawing.GDIPlus:GdiplusStartup (ulong&,System.Drawing.GdiplusStartupInput&,System.Drawing.GdiplusStartupOutput&) at System.Drawing.GDIPlus..cctor () [0x00000] in :0 --- End of inner exception stack trace --- at System.Drawing.KnownColors..cctor () [0x00000] in :0 --- End of inner exception stack trace --- at System.Drawing.SystemColors.get_ControlLightLight () [0x00000] in :0 at Deska.Theming.Theme..ctor () [0x00000] in :0 at (wrapper managed-to-native) System.Reflection.MonoCMethod:InternalInvoke (System.Reflection.MonoCMethod,object,object[],System.Exception&) at System.Reflection.MonoCMethod.InternalInvoke (System.Object obj, System.Object[] parameters) [0x00000] in :0
If anyone can help, I'd really appreciate it. Thanks!
