References to localhost changed to mydomain.com otherwise Stack Exchange doesn't allow me to post.
I am using OpenLayers 3 to show a map. I can successfully show vectors on the map by using a GeoJSON or KML source from a URL. However, for larger maps with thousands of areas I'm trying to use GeoServer to serve an ImageWMS layer.
If I navigate to http://mydomain.com:8080/geoserver/...rs&bbox=-180.0,-90.0,180.0,90.0&srs=EPSG:4326 then I can see the map in my browser. However, when I call it from code I can only see the underlying OSM tile. My snippet of JavaScript which renders the layer is:
var layers = [];var tile = new ol.layer.Tile({ source: new ol.source.MapQuest({layer:'osm'}) });layers[0] = tile;var geoserverRoot = '@ConfigurationManager.AppSettings["GeoServerUrl"]';var params = { LAYERS: 'areas_for_type', FORMAT: 'image/png', viewparams: 'typecode: ' + areaType};var wmsImage = new ol.layer.Image({ opacity: 0.3, source: new ol.source.ImageWMS({ url: geoserverRoot + 'wms', params: params })});layers[1] = wmsImage;wmsImage.addEventListener("change", function() { map.getView().fitExtent(wmsImage.getExtent(), map.getSize());});var map = new ol.Map({ target: 'map-container', layers: layers, view: new ol.View({ center: [0, 0], zoom: 2 })});there are no JavaScript errors and the GeoServer log shows:
2014-11-10 11:27:58,546 INFO [geoserver.wms] - Request: getMap Filters = null Tiled = false Palette = null FeatureVersion = null SRS = urn:x-ogc:def:crs:EPSG:3857 Styles = [StyleImpl[ name=polygon]] Layers = [org.geoserver.wms.MapLayerInfo@72adad35] MaxFeatures = null Crs = PROJCS["WGS 84 / Pseudo-Mercator", GEOGCS["WGS 84", DATUM["World Geodetic System 1984", SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]], AUTHORITY["EPSG","6326"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AXIS["Geodetic latitude", NORTH], AXIS["Geodetic longitude", EAST], AUTHORITY["EPSG","4326"]], PROJECTION["Popular Visualisation Pseudo Mercator", AUTHORITY["EPSG","1024"]], PARAMETER["semi_minor", 6378137.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["Easting", EAST], AXIS["Northing", NORTH], AUTHORITY["EPSG","3857"]] Bbox = SRSEnvelope[-3.2580518936273526E7 : 3.2580518936273526E7, -1.1740727544603072E7 : 1.1740727544603072E7] Env = {} Angle = 0.0 CQLFilter = null Elevation = [] FeatureId = null StartIndex = null ViewParams = [{TYPECODE= AdministrativeWard}] RemoteOwsType = null RemoteOwsURL = null FormatOptions = {} BgColor = java.awt.Color[r=255,g=255,b=255] Transparent = true SldBody = null Sld = null StyleUrl = null StyleFormat = sld ValidateSchema = false TilesOrigin = null Exceptions = SE_XML StyleBody = null SldVersion = null StyleVersion = null Height = 600 Width = 1665 Filter = null Time = [] Format = image/png Buffer = 0 Request = GetMap RawKvp = {CRS=EPSG:3857, BBOX=-32580518.936273526,-11740727.544603072,32580518.936273526,11740727.544603072, TRANSPARENT=true, VERSION=1.3.0, FORMAT=image/png, SERVICE=WMS, VIEWPARAMS=typecode: AdministrativeWard, HEIGHT=600, REQUEST=GetMap, LAYERS=areas_for_type, STYLES=, WIDTH=1665} Get = true BaseUrl = http://mydomain.com:8080/geoserver/ RequestCharset = UTF-8 Version = 1.3.0Why is this not showing on the map if there are no errors?
