Map automation to iterate through attribute table using ArcPy?
I have a python code which iterates through all attribute fields and creates a map for each field automatically. However, in the code I have to specify each attribute manually which was fine so far. Now I have an attribute table with many fields and I need a way to do the same without specifying the attributes manually (as done with "Attrlist" in the code. Any suggestions?
This is the code I am using so far:
outPath = "D:\\Atlas\\test\MxdMaps\\Mxd_MapAutomation\\" # list of attributes with the same datatypeattrlist = ["EthnicGroups_totnumberoffarmhh_txt_WNHDeAA01", "EthnicGroups_totnumberoffarmhh_txt_WNHDeAA02", "EthnicGroups_totnumberoffarmhh_txt_WNHDeAA03"]# layer which has to change the attribute fieldfeaturelayer = arcpy.mapping.ListLayers(mxd, "EthnicGroups_totnroffarmhh")[0]# text element that has to change (e.g. title...)title = arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "map_title")[0]for attr in attrlist: #if featurelayer.symbologyType == "GRADUATED_COLORS": #print attr # change value field featurelayer.symbology.valueField = attr #featurelayer.symbology.addAllValues() featurelayer.symbology.reclassify() #print "Break values: %s" % featurelayer.symbology.classBreakValues # change tilte title.text = attr # update view arcpy.RefreshActiveView() arcpy.RefreshTOC() # export as jpeg outJPEG = os.path.join(outPath, attr + ".jpg") arcpy.mapping.ExportToJPEG(mxd, outJPEG, "PAGE_LAYOUT", 200, 200, 300, False, "24-BIT_TRUE_COLOR", 90, False) # export as AdobeIllustrator .ai #outAI = os.path.join(outPath, attr + ".ai") #arcpy.mapping.ExportToAI(mxd, outAI, "PAGE_LAYOUT", 200, 200, 300, "BEST", "RGB", "VECTORIZE_BITMAP", False)del mxd
