Loop through columns Python arcpy.ListFields
I am trying to run a Python script that loops through all fields in my input feature attribute table. I have searched extensively and tried to use arcpy.ListField to work but it seems all people got stuck on the same issue: we cannot get the columns we are trying to loop to work as input field.
Here is my script:
import arcpyarcpy.env.workspace = "C:\Users\jacobyan\Desktop\JACOB"fieldList = arcpy.ListFields("BG_SAR1.shp")try: #Call all fields in the list for field in fieldList: outputname = str(field.name) + ".shp" print outputname arcpy.ClustersOutliers_stats("BG_SAR1.shp", "field", outputname, "GET_SPATIAL_WEIGHTS_FROM_FILE","EUCLIDEAN_DISTANCE", "ROW", "#", "SpatialWeights.swm","NO_FDR")except: print arcpy.GetMessages()The result I got is:
FID.shp Executing: ClustersOutliers C:\Users\jacobyan\Desktop\JACOB\BG_SAR1.shp field C:\Users\jacobyan\Desktop\JACOB\FID.shp GET_SPATIAL_WEIGHTS_FROM_FILE EUCLIDEAN_DISTANCE ROW # C:\Users\jacobyan\Desktop\JACOB\SpatialWeights.swm NO_FDR Start Time: Wed Jul 29 14:45:56 2015 Failed to execute. Parameters are not valid. ERROR 000728: Field field does not exist within table Failed to execute (ClustersOutliers). Failed at Wed Jul 29 14:45:56 2015 (Elapsed Time: 0.03 seconds)
I adjust "field" to "field.name" and try to replace it with FieldList[count], but none of those worked.
Here are two related posts I have looked at:Iterating through columns in table using ModelBuilder?
https://geonet.esri.com/thread/56324
Any help is much appreciated!
