I am just starting yo use liblas and I had a small issue and I am hoping that you can help me.
I have next code to generate a las file with geo-referenced points:
std:
fstream ofs; liblas::Header header; liblas::SpatialReference srs; srs.SetFromUserInput("EPSG:4326"); header.SetSRS(srs); header.SetPointRecordsCount(1); ofs.open("H:\\temp\\test2.las", std::ios:
ut | std::ios::binary); liblas::Writer writer(ofs, header); liblas:
oint point(&header); point.SetCoordinates(1.0, 2.0, 3.0); writer.WritePoint(point); point.SetCoordinates(5, 5, 5); writer.WritePoint(point); point.SetCoordinates(-1, -1, -1); writer.WritePoint(point); header.SetPointRecordsCount(3); writer.SetHeader(header); writer.WriteHeader(); ofs.Close(); When I run lasinfo over this file I get: (It says that I have 3 points, but my spatial reference is none) enter image description here
Same code above, but if I comment this line:
//writer.SetHeader(header); (I can see the spatial reference, but the number of points is 1) enter image description here
Am I doing something wrong?
Thank you!
std:
Thank you!
