I am new with leaflet and I need help to change the color of a polygon on a choropleth map dynamically.
In my website I have an slider, and depending on the position of the handle, the colors of the polygons of the map vary. So I need to make these changes automatically.
I have found two options to do so, but they are too slow.
PD: I try to explain my problem as well as possible, however if there is something that you do not understand I could explain it with more details.
- The first solution is to remove all the map and to create another one with the updated information. As the map is formed of several poligons it takes too much time so it is not a good solution.
- The second one is to introduce a new layer to the map with the information of the updated polygons above the old ones. Although at first it works well after several changes the map goes slower.
- The first one is to use "onEachFeature" function. However as in my case the changes of the map are not related with the mouse events I don't know how to activate it.
- The second one is to make the changes on the poligons of the map manually, but I don't know if it would be posible.
