I have a question for you and it is about the labels that I need to be remove/delete/turn if off.
So you have all the data set up and the labels set up but they were in the Data View..
My question here is how do I turn the labels off while you are in the Layout View ? I don't want to go into the Data View, because if you do make any changes in it. It will change everything if you go back to the Layout View .
