So in my Openlayers 3.9.0 I use Bing Maps and OSM layers, they both are EPSG 3857
var layer = new ol.layer.Tile({ source: new ol.source.OSM({}) }); var bingMapsAerial = new ol.layer.Tile({ source: new ol.source.BingMaps({ key: '////', imagerySet:'AerialWithLabels' }) }); I set the extent that the layers mast fit in
var textent = ol.proj.transformExtent([2297128.5, 4618333, 2459120.25, 4763120], 'EPSG:900913', 'EPSG:3857'); I also set a layer from PostGIS
var ait = new ol.layer.Tile({ extent: textent, source: new ol.source.TileWMS({ url: 'http://localhost:8080/geoserver/mymap/wms?', params: {'LAYERS': 'mymap
olygon, mymap:line', 'TILED': true, 'VERSION': '1.3.0','FORMAT': 'image/png' ,'CRS': 'EPSG:3857'}, serverType: 'geoserver' }) })My view is
var view = new ol.View({ center: center, extent : textent, zoom: 6, maxZoom:20});and my map
var map = new ol.Map({ target: 'map', layers:[bingMapsAerial, layer, ait], view: view});map.getView().fit(textent, map.getSize()); The raster tile layer is in EPSG 900913 in PostGIS and Geoserver says EPSG:900913 as Native SRS and Declared SRS. Both polygon and line layers that compose the tile layer have slightly different Native Bounding Box and Lat/Lon Bounding Box, but they render the same spatial region.Both polygon and line layers have Published zoom levels and Cached zoom levels set to 0 -20 in Geoserver to match the Openlayers View settings
Aren't EPSG 900913 and EPSG 3857 supposed to be the same?
Both Bing and OSM layers look ok, but the tile layer appears smaller than the other two.
How do I proceed? Am I missing something, a setting or var? Is there a hack? I have to convert the PostGIS data?
Thanks
Thanks
