Krooki to Google Maps - UTM to Degrees
Following to a previous tool I have developed to convert data projection from Clark 1880 to WGS84 and as a request from many viewers to develope similar tool in Google Maps. I am Happy to announce the birth of Krooki to Google Maps application. This application allows input using x, y coordinates or what called UTM coordinates (Northing, Easting) directly from the krooki and then it converts the coordinates to degrees which are acceptable by Google Maps and it will locate the plots coordinates on Google Satellite maps. This conversion is accurate in Oman only as its uses Zone 40 parameters
Krooki to Google Maps V1.1
