KML file seems to load in Openlayers without error but doesn't show vectors
I'm trying to load a KML file into an Openlayers map. It seems to successfully run but I am not seeing anything show up on the map.
Vectors should show up in an area of New Mexico if it's working correctly.
Here is my code (here is a link to the KML file )
var map;var baseMaps = [];var sensors = [];//create map and center over locationvar init = function () { // create map map = new OpenLayers.Map({ div: "map", theme: null, projection:new OpenLayers.Projection("EPSG: 4326"), controls: [ new OpenLayers.Control.Attribution(), new OpenLayers.Control.TouchNavigation({ dragPanOptions: { enableKinetic: true } }), new OpenLayers.Control.Zoom() ], layers: [ new OpenLayers.Layer.OSM() ] }); map.setCenter(new OpenLayers.LonLat(-106.7653, 32.3197).transform(new OpenLayers.Projection("EPSG:4326"), map.getProjectionObject()),9);};//show kmlFilevar showSensor = function(sensorVO){ if(sensorVO.selected == true) { var kmllayer = new OpenLayers.Layer.Vector("KML", { strategies: [new OpenLayers.Strategy.Fixed()], protocol: new OpenLayers.Protocol.HTTP({ url: sensorVO.url, format: new OpenLayers.Format.KML({ extractStyles: true, extractAttributes: true, maxDepth: 2 }) }) }); map.addLayer(kmllayer); var select = new OpenLayers.Control.SelectFeature(kmllayer); map.addControl(select); select.activate(); map.setCenter(new OpenLayers.LonLat(-106.639261,32.649908).transform(new OpenLayers.Projection("EPSG:4326"), map.getProjectionObject()),10); var obj = {"vo":sensorVO, "kmlLayer":kmllayer}; sensors.push(obj); } else { for (var i = 0; i < sensors.length; i++) { var vo = sensors.vo; if(vo.id == sensorVO.id) { map.removeLayer(vo.kmlLayer); sensors.splice(i, 1); } } }}init();setTimeout(function(){ var obj = {"id":1, "selected":true, "url":"kml-files/1858-Vegitation-Map.kml"}; showSensor(obj);}, 1000);
