I am trying to export selected features from layers from SDE into a DXF using python, but it does not retain the layer name. But if I do it manually using the ArcToolbox tool, it does work. Example below
Layers in MXD
DXF in AutoCAD - which was created using the Export to CAD tool in ArcToolbox
DXF in AutoCAD - which was created using the python code below
The code that I run is below
mapDoc = r"C:\temp\DXF_Test10_v5.mxd" mxd = arcpy.mapping.MapDocument(mapDoc) df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0] #Go through teh bookmarks layer fields = "FULLNAME" #location = "City of London" location = "Golden Lane Estate" expression = "\"FULLNAME\" = '" + location + "'" for layer1 in arcpy.mapping.ListLayers(mxd): if layer1.name == "Bookmarks": with arcpy.da.SearchCursor(layer1, fields,expression) as cursor: for row in cursor: #select the record arcpy.SelectLayerByAttribute_management(layer1, "NEW_SELECTION", expression) #do select by location, select all the layers apart from bookmarks inFeatures = '' listOfLayers = [] #loop through all the layers in teh map for layer in arcpy.mapping.ListLayers(mxd): if layer.name "Bookmarks": if layer.isGroupLayer == False: print layer.longName if layer.visible == True: listOfLayers.append(layer) #select the features that intersect arcpy.SelectLayerByLocation_management(layer, "INTERSECT", layer1, "", "ADD_TO_SELECTION") count = int(arcpy.GetCount_management(layer).getOutput(0)) print count #print inFeatures #export to cad #arcpy.ExportCAD_conversion(listOfLayers, "DXF_R2010", r"H:\Corporate GIS and Web Mapping\Data_Repository\DXF_TEST" + os.sep + location + ".dxf", "Ignore_Filenames_in_Tables", "Overwrite_Existing_Files", "") arcpy.ExportCAD_conversion(listOfLayers, "DXF_R2010", r"C:\Temp\DXF_COL" + os.sep + location + ".dxf", "Ignore_Filenames_in_Tables", "Overwrite_Existing_Files", "") del mxd Does anyone know why when I run the script it does not honor the layer name?
Layers in MXD
