Join and Calculate vb.net
Im trying to join an excel table to a shapefile and then calculating those fields using vb.net. The code I have written has no errors, but won't work when I try it in ArcGIS 10.1 and I'm out of ideas. If anybody can find an error in my code or direct me to other sources, I'd gladly appreciate it.
ModuleQ3 Code:
Public Sub JoinCalc(ByVal excelXLS As String, ByVal fromExcelTable As String, ByVal toFeatureClass As String, ByVal toField As String, ByVal fromField As String, ByVal calculateField As String, ByVal calculatorExpression As String) Dim pMxDoc As IMxDocument Dim pMap As IMap Dim pFeatureLayer As IFeatureLayer Dim pFeatureClass As IFeatureClass Dim featureIndex As Integer pMxDoc = My.ArcMap.Application.Document pMap = pMxDoc.FocusMap featureIndex = FindLayer(toFeatureClass) If featureIndex = -1 Then MsgBox("The join feature class is not in the current map document.") Exit Sub End If pFeatureLayer = pMap.Layer(featureIndex) pFeatureClass = pFeatureLayer.FeatureClass Dim pWorkspaceFactory As IWorkspaceFactory pWorkspaceFactory = New ExcelWorkspaceFactory 'open excel workbook Dim pFworkspace As IFeatureWorkspace pFworkspace = pWorkspaceFactory.OpenFromFile(excelXLS, 0) 'open excel table Dim pFromTable As ITable pFromTable = pFworkspace.OpenTable(fromExcelTable) 'Join the table to the feature class. Dim pMemRelFact As IMemoryRelationshipClassFactory Dim pRelClass As IRelationshipClass Dim pDispRC As IDisplayRelationshipClass ' Create a memory relationship class. pMemRelFact = New MemoryRelationshipClassFactory pRelClass = pMemRelFact.Open("Table-Layer", pFromTable, fromField, pFeatureClass, toField, "FeatureClassName", "TableName", ESRI.ArcGIS.Geodatabase.esriRelCardinality.esriRelCardinalityOneToOne) ' Perform a join. pDispRC = pFeatureLayer pDispRC.DisplayRelationshipClass(pRelClass, ESRI.ArcGIS.Geodatabase.esriJoinType.esriLeftInnerJoin) MsgBox("The join is complete") Dim pDisplayTable As IDisplayTable pDisplayTable = pFeatureLayer Dim pFields As IFields pFields = pFeatureClass.Fields Dim fieldIndex As Integer fieldIndex = pFields.FindField(calculateField) If fieldIndex -1 Then Dim pCursor As ICursor pCursor = pDisplayTable.SearchDisplayTable(Nothing, True) Dim pCalculator As ICalculator pCalculator = New Calculator With pCalculator .Cursor = pCursor .Expression = calculatorExpression .Field = calculateField End With pCalculator.Calculate() MsgBox("It should be calculated.") Else MsgBox("The field does not exist") Exit Sub End IfEnd SubThese are the parameters that im passing through:
ModuleQ3.JoinCalc("ONT_Climate_Normals.xlsx", "ONT_Annual", "ONT_Stations_Shape", "CLIMATE_ID", "CLIMATE_ID", "TotalAnnua", "NORMAL_52 + NORMAL_54")
