JetBrains PhpStorm 7.1.3 crack, keygen use to unlock Full version,this software crack, Keygen is 100% working We test it You have to JetBrains PhpStorm 7.1.3 crack or use Keygen patch, and get Full version JetBrains PhpStorm 7.1.3, so JetBrains PhpStorm 7.1.3 crack and Keygen is Done,
JetBrains PhpStorm 7.1.3 software scripting language PHP is an IDE for Web professionals. Php IDE softwareJetBrains PhpStorm is a lightweight and smart and can automatically fix any coding errors. PhpStorm software programming code in PHP, CSS, HTML, XML, YAML, javascript support. Code quality analysis software used in the project will perform a thorough inspection to all problems are displayed on the user’s code to fix whatever’s wrong then automatically renders the software, and all the test of the report Debugging the program is delivered. Code editor for HTML / CSS / javascript gives the user access to all the scripts in a web view to directly edit.
Feature Software JetBrains PhpStorm 7.1.3:
- The programming language Java Script, SQL, XML
- Code bugs, PHP, CSS, HTML, XML, YAML, javascript
- Code editor directly
- Support for HTML 5
- Easy and Fast
- Synchronization feature with FTP
- Test the programming codes
- Code bugs automatically
- Can be installed on Windows OS
JetBrains PhpStorm is easy and convenient editor PHP, which will maximize your performance. Editor understands the code gives handy tips, quick navigation and tracking error “on the fly.” IDE is always ready to help you build your code, run unit tests and provide visual debugging. PhpStorm supports PHP, CSS, HTML, XML, YAML, javascript – everything you need for what would develop its web-site. The seventh version includes support for PHP 5.5, improved syntax highlighting.
Features:
Smart PHP Code Editor
The editor that actually ‘gets’ your code and deeply understands its structure, supporting PHP 5.3, 5.4 & 5.5 for modern and legacy projects. Provides the best code autocompletion, refactorings, on-the-fly error prevention, supports language mixtures and more.
Development Environment
Perform many routine tasks right from the IDE, thanks to Version Control Systems integration (Git, SVN, etc.), Local history, support for remote deployment, SQL and databases, command-line tools, Vagrant, Composer, PHP UML, terminal, built-in REST Client and SSH Console with remote tools.
Debugging and Testing
Zero-configuration debugging makes it really easy to debug your applications, especially with debugger configuration validation.PHPUnit support lets you develop and run unit tests right from the IDE. Profile your applications with Xdebug or Zend Debugger and check aggregated reports in PhpStorm.
HTML / CSS / javascript Editor
All the cutting edge front-end technologies are supported, including HTML5, CSS, Sass, SCSS, Less, Stylus, Compass, CoffeeScript, TypeScript, ECMAScript Harmony, Jade, Emmet, and of course javascript, with refactorings, debugging and unit-testing . There is also Live Edit to see changes instantly in your browser.
Download Link:
http://dl4.download.ir/Download/2014/March/Software/PhpStorm.v7.1.3.Download.ir.rar
zip password: www.download.ir
- Easy and Fast
Features:
Download Link:
