java.lang.IllegalStateException while trying to export SVG with multiple layers
I just recieved this errror (in the following stack trace), while exporting content to an SVG file. I am customly building the svg elements and map contents to export. The code runs fine, however I recently added a dialog option to change the color of a specific line (based on line ID). This works fine in the display window. However I am getting 2 errors while exporting it (only with the custom style).
I believe the problem is because my second styled line is added as a second layer (in the layers table of the JMapFrame), which could be the issue.
The other error is a null pointer when accessing the MapFrame's MapPane.
Any ideas as to why this might be happening?
If any code is needed please say so, it will take me awhile to post what is necessary.
Stack Trace:
java.lang.IllegalStateException: Cannot call paint, you did not set a MapContent in this renderer at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:763) at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:602) at com.mycompany.shapefileexporter.mvn.ExportShapefile.exportToSVG2(ExportShapefile.java:235) at com.mycompany.shapefileexporter.mvn.ShapefileExporter$3.action(ShapefileExporter.java:252) at org.geotools.swing.action.SafeAction.actionPerformed(SafeAction.java:50) at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2018) at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2341) at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402) at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259) at javax.swing.AbstractButton.doClick(AbstractButton.java:376) at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833) at com.apple.laf.AquaMenuItemUI.doClick(AquaMenuItemUI.java:157) at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877) at java.awt.Component.processMouseEvent(Component.java:6516) at javax.swing.JComponent.processMouseEvent(JComponent.java:3321) at java.awt.Component.processEvent(Component.java:6281) at java.awt.Container.processEvent(Container.java:2229) at java.awt.Component.dispatchEventImpl(Component.java:4872) at java.awt.Container.dispatchEventImpl(Container.java:2287) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4832) at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4492) at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4422) at java.awt.Container.dispatchEventImpl(Container.java:2273) at java.awt.Window.dispatchEventImpl(Window.java:2719) at java.awt.Component.dispatchEvent(Component.java:4698) at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:747) at java.awt.EventQueue.access$300(EventQueue.java:103) at java.awt.EventQueue$3.run(EventQueue.java:706) at java.awt.EventQueue$3.run(EventQueue.java:704) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:87) at java.awt.EventQueue$4.run(EventQueue.java:720) at java.awt.EventQueue$4.run(EventQueue.java:718) at java.security.AccessController.doPrivileged(Native Method) at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:76) at java.awt.EventQueue.dispatchEvent(EventQueue.java:717) at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:242) at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:161) at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:146) at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:138) at java.awt.EventDispatchThread.run(EventDispatchThread.java:91)
