Issue: I'm trying to run a model that takes a starting table, converts it to a .dbf, joins it to a shapefile, then applies the symbols from two different layers to the joined shapefile. I've gotten the model to run in the edit window and achieve the desired result. However, when I run the model from the catalog menu, the final result does not meet the desired result. I get one outputted layer with symbology that does not match any of the applied layers. I'm new to model builder and am stuck. Any help would be supper appreciated. Here is the model that I am working with.
