Is there an automatic way to connect attributes of a transformer to the attributes of
I am using FME 2015 in order to build a workflow as shown in the image:
As you can see in the figure I have an AttributeFilter which takes manually some value. I have to run this workflow multiple times for different values in the Attribute Filter. The issue I face is that once I modify the value (in AttributeFilter) then all the connections between the FeatureMerger and the writter (komvoi) are lost and I have to remake them by clicking..
My question is if there an automatic way to do this connection instead of manually.
