I have a raw .las file that I have brought into an ArcGIS .lasd file format. The raw data has several anomalous points ie. the maximum elevation for any point should only be 100 meters. There are perhaps 30 points with an elevation above 1000 meters. I would like to delete these anomalous points. The points are unclassified except for "ground". All others, including the anomalous ones are "unclassified". There doesn't seem to be a way to select these, or filter them out and then write a new .las / .lasd file that has eliminated them.Thank you in advance....!
